01-05-2005 04:18 AM
Hello all!
I am trying to configure SAA so that when I have an outage on a path, a traceroute is triggered that stores hops in history and therefore records exactly where the outage occured.
At the moment, I am doing some testing to see if this is possible. When the IP address the SAA PathEcho probe is monitoring is reachable, I can record the hops in the history. However, when the IP address is not reachable, no history is recorded! A debug IP Packet also shows that the PathEcho probe does not seem to timeout - it seems to keep sending packets beyond the life of the probe, which for testing purposes I have at 60 seconds..
An example config I am using is shown below and I've shown the results when the IP address is up: Am I missing anything to be able to record history when the destination IP is down/unreachable?
Many thanks in advance!
rtr 1
type pathEcho protocol ipIcmpEcho 212.74.64.138 source-ipaddr 10.50.71.35
tag Test to route-server.colt.net
lives-of-history-kept 1
samples-of-history-kept 15
filter-for-history all
rtr schedule 1 start-time now life 60
SAA_Test#show rtr history 1
Point by point History
Entry = Entry number
LifeI = Life index
BucketI = Bucket index
SampleI = Sample index
SampleT = Sample start time
CompT = RTT (milliseconds)
Sense = Response return code
Entry LifeI BucketI SampleI SampleT CompT Sense TargetAddr
1 1 1 1 102763753 2 1 10.50.70.18
1 1 1 2 102763754 2 1 10.50.128.1
1 1 1 3 102763754 5 1 nnn.nn.nn.nn
1 1 1 4 102763754 4 1 nnn.nn.nnn.nn
1 1 1 5 102763755 5 1 nn.nnn.nnn.nn
1 1 1 6 102763756 6 1 212.113.11.113
1 1 1 7 102763756 6 1 212.187.131.154
1 1 1 8 102763757 6 1 212.113.3.30
1 1 1 9 102763758 5 1 195.66.224.49
1 1 1 10 102763758 6 1 212.74.64.13
1 1 1 11 102763759 6 1 212.74.64.138
01-11-2005 12:13 PM
Your config looks fine, should work. But how are you storing the history ? Using Syslog server ? Did you change the severity from default?
01-13-2005 06:45 AM
I was looking on the router using the show rtr history commmand, however I've just checked my syslog server and I am seeing the history messages.
Many thanks.
