Database requirements for LMS 2.5
davinder
Do I need a SQL database for LMS 2.5?
sstudsdahl
Level 4
Level 4
No, you won't need an SQL database setup for LMS 2.5. All of the applications that use a database will setup its own database as you install the software.
Steve
sstudsdahl
Level 4
Level 4
Duplicate post from above
