DCHP Failed
ryanj88
I'm trying to get my network to take DHCP but I keep getting the message DHCP failed APIPA is being used. I'm at a loss for what I need to do. I'm linking the Packet Tracer assignment if anyone can help, it would be much appreciated. I'm not sure how to link the direct Packet Tracer file on here because it says that .pkt is not supported.
You can put your .pkt file in a zip folder and attach that.
After reading the assignment it shows you how to do it. Could you walk us through what you did exactly? Did you include the helper addresses on the right interfaces as well as do you have reachability to the server from all LAN segments?
-David
So I followed along with the assignment. When it came to applying DHCP addresses in the Server DHCP services, I think this is where I messed up. I've been in this class for two weeks and this still seems so foreign to me.
