DCNM 11.2(1)
georgip
DCNM is used in LAN Fabric. We are on the latest 11 version. There are number of policies which you can apply to nodes.
What is the policies or switch_freeform configs that should be used to apply filtering to BGP neighbors (Route Maps/Prefix List)?
Do you use any custom or pre-build policies/freeforms which you think are missing from the templates?
Thanks in advance.
Joro.
0 Replies 0
