DCNM 6.x - Backup Nexus configuration
MathieuJM_2
I'm busy on configuring the backup of the configuration from Nexus switches 5K and 7K.
I have installed COPSSH on my windows server and try to confiugre the sftp credentials.
I have the following error:
Verification failed to back up file from 'ip_address'.
Please see Admin>Logs>Web Report
In the Web report i have :
N5K#
2012.12.05 15:03:31  INFO  [FM.WebReport] Remote copy failed.  copy bootflash:ip_address-121205-150329-TEST sftp://SvcCOPSSH@ip_address/ip_address-121205-150329-TEST   vrf management
ssh: connect to host ip_address port 22: No route to host
Couldn't read packet: Connection reset by peer
N5K#
2012.12.05 15:03:33  INFO  [FM.WebReport] Remote copy failed.
2012.12.05 15:03:33  INFO  [FM.WebReport]  show switchname > bootflash:ip_address-121205-150329-TEST
N5K# delete bootflash:ip_address-121205-150329-TEST
N5K#
Failed to back up file from 'ip_address': Please see web reports logs
I have tested from the CLI from the switch and i have the issue but if i use the default vrf 'default' it works fine.
How can i change the command sent by DCNM to the Nexus in order to specify vrf default and not vrf management ?
Cheers
Luis Perez
Hi Mathieu have you solved this problem, because i have the same
martin_ced
hello,
i also have this problem, even if i use TFTP or SFTP... Everything is ok with CLI, but nothing with backup jobs ...
if anybody can help .
Thanks in advance
Hi guys, I have the same problem with four nexus 5596up, but with others 5548 it works fine with TFTP, by you use sftp need to have a License that its called FM_SERVER, only for SAN environment, if someone can resolved this issue i really want to share with us this solution
best regards
aruls
In the past releases these issues are fixed. Now DCNM will be able to take backup through default or management vrf's.
