DCNM Upgrade Base System RHEL Upgrade
sdnscottie
Hello Community,
you guys know the guidelines for Updating the Base System ?
I don't seem to find the recommendation for periodic :
yum update
yum upgrade
Or do we only restrict ourselfs to upgrade the Cisco DCNM Linux using GUI?
Here ref: Cisco DCNM Installation/Upgrade guide 11.5(1)
kind regards,
Scottie
Hi Marcel,
thanks for the feedback. Yes, I found the official Reference /Admin Guide .
and this valuable video
which demonstrates using the inline-upgrade method.
Scottie.
sdnscottie
AS a follow up :
on my test DCNM virtual appliance, version 11.5.1
yum update && yum upgrade
were successful.
System is more responsive ...   So thats interesting.
I will be posing a TAC-CASE concerning this issue; but I was also hoping on community feedback
Nevertheless, I'll provide you guys the Feedback from the tac.
Kind Regards, Scottie
 - Usually as it being an appliance this may work, but not will be certified or supported if problems with DCNM start appearing.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Marcel,
Scottie.
