DCR Device Discovery
jwright
I replaced a 4003 switch with a 4503 within our network.   The switch type change was not detected automatically and rediscovery did not change anything.  I deleted the device but now discovery does not rediscover.  It does show up as a cdp neighbor with two seed devices.  It doesn't even show up as an unknown device.  I've verified snmp config on the device in question.  I've also reentered the snmp read only string within discovery options.
Ideas?
5 Replies 5
Joe Clarke
What version of LMS do you have?
Ver. 3.2
Post your NMSROOT/conf/csdiscovery/CSDiscovery-config.xml as well as the show run from this switch.
What is the relevant portion of the show run you need to see?  I can't post the entire switch config.
I need to know all of the IPs configured on the device, and I need to make sure the community string has a proper view.
