DCR error message in Cisco Works
russnash
get error message:Error in communicating with DCR server.
Went in an restart server but still getttin message.
DCR log is attached.
AFROJ AHMAD
Hi ,
Seems to be Certificate has expired on the LMS server:
java.security.cert.CertificateExpiredException: NotAfter: Sun Jan 13 09:22:18 CST 2013
    at sun.security.x509.CertificateValidity.valid(CertificateValidity.java:256)
Genearte a new certificate and check the issue :
To generate a new certificate in LMS
1. Stop the daemon Manager
a. Windows: net stop crmdmgtd
b. Solaris: /etc/init.d/dmgtd stop
1. Remove the following certificate files from (NMSROOT/MDC/Apache/conf/ssl)
a. server.crt
b. server.key
c. server.pk8
d. server.csr
2. Disable SSL:
for E.g
D:\Program Files\CSCOpx\bin>perl "D:\Program Files\CSCOpx\MDC\Apache\ConfigSSL.pl" -disable
3. Enable SSL to generate certificate:
D:\Program Files\CSCOpx\bin>perl "D:\Program Files\CSCOpx\MDC\Apache\ConfigSSL.pl" -enable
4. Start Daemon Manager
I hope this will help
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
a. server.crt
b. server.key
c. server.pk8
d. server.csr
2. Disable SSL:
for E.g
Afroz
found another thread that hopefulle fixed my issues.
aamircisco
Hi Afroz,
i am having a problem login into LMS VERSION 4.0 . As soon as i enter username and password . the page shows error mentioned below.
Forbidden
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
I have been searching for the solution from past 2 days. no success. please help .
regards,
AAMIR
