debugging a traffic of a specific IP on cisco routers
amino1982
if i need to debug the traffic of only one ip address on a cisco router , how can i do this??
i know that an access list may be used , but please clarify the method for me?
amritpatek
Level 6
Level 6
DEBUG TRAFFIC BASED ON AN ACCESS LIST:
The debug procedure is the following:
PLEASE make sure to use this commands very carefully. If there's a lot of traffic between
hosts you may crash the router.
1) Turn "on" process switching under both interfaces in the router.
Router(config)#interface
Router(config-if)#no ip route-cache
2) Create an access-list. Define specific traffic you want to monitorbetween hosts. For
example:
Router(config)#access-list 199 permit tcp host x.x.x.x eq host y.y.y.y
Router(config)#access-list 199 permit tcp host y.y.y.y eq host x.x.x.x
3) If you are in a telnet session into the router turn "terminal monitor" on.
Router#term mon
If you are in a console session into the router, then the "logging console" command.
Router(config)#logging console
4)Finally the debug command.
Router#debug ip packet 199 detail
Where 199 is the access-list # we created.
5)Use the "un all" command to turn it off.
Router#un all
Here is a link also where you can find this procedure.
Using the Debug command.
http://www.cisco.com/warp/public/63/ping_traceroute.html#usingdbg
If you turn on "process switching" on only one interface, you will only be able to debug
traffic on that particular interface as well.
Thank You for your help
