IOS upgrade through RME
I am using Cisco Works 2.6, RME 4.0.5 and want to upgrade the IOS of a WS-C3750-24TS-E switch. I have downloaded the IOS "c3750-advipservicesk9-mz.122-25.SEE4.bin" from cisco and added it to software repository through rme->software mgmt->software repository->add.
Now I selected the IOS and selected update status after which the IOS status changed to "not deffered".
Now to upgrade the ios on switches,which are detected as "Cisco 3750 Stack " , chossing software distribution -> by image . Then selecting the same IOS and device from select image and device window. after selecting next it shows me device name , module information and storage option properly. On the next step in verification window I am getting the following errors in verification details...
testsw
File_Name : /c3750-i5-mz.121-19.EA1d.bin
File_Size : Unknown
Family : C3750
Version : 12.1(19)EA1d
BOOTROM : Bootstrap program is C3750 boot loader
RAM : 134209536
Feature : LAYER_3|MIN_DRAM_MEG=64
Media : RAM
Image_Type : SYSTEM_SW
Software_Name : C3750-I5-M
SOURCE : flash:
UPGRADETYPE : ACTIVE
Flash Information
Flash Name : flash
Flash Size : 15991309
Flash Free : 11938304
Verification Errors And Warnings
SWIM1063: Minimum RAM requirement of the selected image cannot be determined.
RAM available on the device may not be enough to activate this image.
Update the minimum RAM value using View/Edit Image attributes or
make sure that the device has enough RAM to activate the selected image or select a different image.
SWIM1110: .bin images are not supported for Stack Upgrade.
Select a tar image for Stack Upgrade.
Pls let me know where I am wrong and what exact I have to do the upgrade IOS.
Sven Hruza
Level 4
Level 4
I think you should download the tar-file of the IOS you want to use like the error SWIM1110 tells it.
Because the Stack-Switches can't use bin-files.
Sven
Sven Hruza
Level 4
Level 4
Sven
But this switch is not connected to any stack.
In the repository you can select the IOS.
There you can modify the "Minium RAM" and "Minimum Flash".
This informations you can get from cisco.com I think.
Then the first error message should be fixed.
Sven
Thanks sven..
well I resolved the problem . It was only because of that .tar format image. I had downloaded that from cisco site and upgraded the IOS of that switch.
