Destination Host Unreachable
R.Florin
Hi,i have a problem in Packet tracer,im trying to ping from Lan 1,PC 11 and PC11 to Lan 2,PC 21 and im getting this error "Destination host unreachable.Can someone help me please ? Thank you !
I uploaded the pkt.
Seb Rupik
Hi there,
R1 has no route to the destination subnet 10.200.200.0/24 and also R2 (hostname R20)  does not has ip routing enabled. to fix this apply the following:
!R1
ip route 10.200.200.0 255.255.255.0 10.0.0.2
!R20
ip routing
Ideally you should want to configure an IGP instead of static routes, in which case the following is preferred:
! R1
router ospf 1
 passive-interface default
 no passive-interface GigabitEthernet0/0
 network 10.0.0.0 0.0.0.255 area 0.0.0.0
 network 10.100.100.0 0.0.0.255 area 0.0.0.0
! R20
ip routing
router ospf 1
 network 10.200.200.0 0.0.0.255 area 0.0.0.0
cheers,
Seb.
Hello,It's working now.Thank you !
@R.Florin  That is good to hear. I hope you can see why using an IGP is preferable to static routing. Please mark this post as answered.
cheers,
Seb.
