Detect Proxy ARP Connection and Get Interface Down by EEM
Daehee Seo
if proxy arp exist in network, I want to detect Proxy ARP on Catalyst to shutdown interface.
I use sla to detect proxy arp reply for unknown IP address.
And I put in ARP Inspection to print Log.
I would like to get port own which is printed in log.
If anyone have better idea, Please let me have help.
====To Detect Proxy ARP====
ip sla 1
 icmp-echo 192.168.0.254
 timeout 340
 threshold 250
 frequency 5
ip sla schedule 1 life forever start-time now
ip sla enable reaction-alerts
====To Create Log====
ip arp inspection vlan 1
ip arp inspection filter test vlan  1 static
arp access-list test
 deny ip host 192.168.0.254 mac any log
 permit ip any mac any
====Log Created by DAI===
08:59:55.259: %SW_DAI-4-ACL_DENY: 1 Invalid ARPs (Res) on Fa0/1, vlan 1.([58bc.2756.d4c0/192.168.0.254/0024.13fc.aac0/192.168.0.2/08:59:55 UTC Mon Mar 1 1993])
SEO
2 Accepted Solutions
Joe Clarke
Something like this should work:
event manager applet kill-proxy-arp
 event syslog pattern "SW_DAI-4-ACL_DENY:.*on [a-zA-Z0-9/]+,"
 action 1.0 regexp "SW_DAI-4-ACL_DENY:.*on ([a-zA-Z0-9/]+)," $_syslog_msg match intf
 action 2.0 cli command "enable"
 action 3.0 cli command "config t"
 action 4.0 cli command "int $intf"
 action 5.0 cli command "shut"
 action 6.0 cli command "end"
Just expand the regexp to:
event syslog pattern "SW_DAI-4-ACL_DENY:.*on [a-zA-Z0-9/]+,.*\(\[[0-9a-fA-F\.]+/192.168.0.254/"
5 Replies 5
Joe Clarke
Hi Joseph,
I appreciate that you help me solve my problem with your perfect answer.
I have a question about scrip.
If I want to disable port which specific IP address(ex:192.168.0.254) comes up,
How do I need to change your script?
Can you help one more time?
SEO
Hi Joseph,
Your answer is perfect.
I did lab with your script.
It works like what I want.
I appreciate for your great help.
SEO
 Click my site
