Device configs are stale
Tod Larson
Level 3
Level 3
How do I configure LMS 3.2 to periodically update it's knowledge of the device configuration?
Last week, I setup a poller to tell me whenever a router interface goes down.  HUM started reporting threshold violations on a few gre tunnels that were left over out on my network.  I went our to the router and remove the gre tunnel interfaces.  Yet, still HUM is reporting that those tunnels are down.
Is there a job that should be running periodically that will tell HUM that those interfaces no longer exist on the nextwork?
Joe Clarke
A thread should be running out of UPMProcess which detects ifIndex and ifAdminStatus state changes.  The logs are IfAdminStatus.log and UPMChangeDetection.log.  Check to see if you're seeing any errors in those logs.
Sir,
Where do I find  IfAdminStatus.log and UPMChangeDetection.log?
Thank you,
TOd
On Windows under NMSROOT\log and on Solaris under /var/adm/CSCOpx/log.
