05-30-2008 08:12 AM
I want change the credential on all devices
on common services including standard and snmp credential. I have tried to edited all at once. but not successful.still keep the old credential.
Solved! Go to Solution.
05-30-2008 08:54 AM
I just tested this again in CS 3.1.1, and it works. Select all the device you want in DCR, then click "Edit Credentials". Modify the credentials you want to change, then click Finish. They should all be updated.
05-30-2008 08:54 AM
