Device Not Reachable
shahulhameed
Level 3
Level 3
Dear All
Devices are not reachable why ?
Thanks and Regards,
Shahul
Vinod Arya
I will tell you in context of IOS, similar structure is for NX-OS, but the commands may differ.
For snmp v3 to work properly, you need to configure it in three steps :
1. Create View (to define what is accessible/inaccessible to a user in that view)
2. Create Groups (Member of that view(s))
3. Create user (member of the group(s)).
In your config I see the view is assocated to default view, i would recommend to change it and try to configure a new one.
snmp-server group PXXX2013 v3 auth write v1default
snmp-server group PXXX2013 v3 auth read v1default
Also, the same group name when executed twice, should have only last command executed, so your group command should be like this :
snmp-server group PXXX2013 v3 auth read xxxxx write xxxxxx
v1default is a default view, may be having issues. Confiugure new view this way :
snmp-server view testView iso included
snmp-server view testView xxxx excluded   ----> (optional, in case we want to exclude anything for restricted access)
Rest all seems good. After adding correct credentials in LMS, try to open device in device centre and do a snmpwalk to see if it works.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
