10-24-2011 05:40 AM
Hi Guys,
Does anyone know if the WLC 4400 is supported in LMS 4.1 in CiscoView.
When I check device update in admin-system-software center. I don't see any available package for the WLC 4400.
Best Regards,
Joris
Solved! Go to Solution.
10-24-2011 05:52 AM
WLCs (2100, 4400 or 5500 series) are not supported by the CiscoView module. Please refer to the supported devices table here.
Hope this helps.
10-24-2011 05:52 AM
Hope this helps.
