device still present after deleting in database
david de sousa
                   Hi guys,
I have a problem with LMS 4.2, i had some device that i deleted from the LMS manually trough the inventory. ths devices are not present anymore in my infrastructure. but a few days ago, some alerts come back to the fault monitor with that device "not responsive", so i went in CLI to the DFM and remove all the devices not present. everything was good, but some days later, the alert come back again.
so, my question is: where the lms keep the informations about the devices? i thought it was in the DFM, but it seems there is another place.
any suggestion?
and to continue, i have some problem with VSS, i can't manage it perfectly, some days i can see the the port and ip in Fault Device Detail and some days i can't. i have some alerts about Interface VLAN down, but the interface AND the VLAN are not present anymore. i deleted the device, then rediscovered it, it works few days, then reappair... i'm just ready to burn all the LMS ^^
Some ideas?
thanks
David
AFROJ AHMAD
Hi David,
You have deleted the devices from DFM CLI you mean  dmctl ?
if yes and you are still getting alerts from DFM then it could be a database sink-up issue.
If these messages really bother you then I can suggest you to RE-Intialize the DFM database (  IF Possible ) but make sure you remove the .RPS files which have the  DFM databses transaction in it.
Below is the procedire to RE-INT DFM database:
1) Stop the daemons:
net stop crmdmgtd
2) Issue these commands from CSCOpx\bin folder:
perl dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
perl dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
perl dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
3) Delete DFM.rps and DFM1.rps:
CSCOpx/objects/smarts/local/repos/icf/DFM.rps
CSCOpx/objects/smarts/local/repos/icf/DFM1.rps
4) Start the daemons:
net start crmdmgtd
For VSS , Kindly open a new thread.
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi David,
net stop crmdmgtd
net start crmdmgtd
Thanks-
Afroz
Hi Afroz,
thanks for the reply, effectively, i already did that, the problem was in the management, it seems some devices became "suspended" after the reinitialization of the databases. i re-managed it and it works good.
thanks
David
