Device Syncronization -
getwithrob
Level 3
Level 3
Is it possible to syncronize across different servers? This is a unique configuration. They have 3 systems running RME and 6 boxes running campus manager. There are right at 11,000 nodes between the 3 RME boxes. However, RME and the CM boxes are out of sync with each other by about 400 nodes. This prompted me to see if device syncronization could occur across platforms.
steve.busby
Level 5
Level 5
Looking at the configuration screen the ANIServer.properties file for device synchronization, it appears to be a one-to-one relationship.
Edited: You could do multiple bulk synchronizations from ANI to the different RME systems. Just change the Essentials Server creditals each time.
Steve
