Devices Discovered by CS, not being discovered in Campus
sirbaughmf
I'm troubleshooting why a few of my devices are being discovered by CS Discovery, however, they are not getting discovered by Data Collection, therefore, I'm not able to see them in Campus. Below is an error in topo.log file. Can you give me a hint as to why I wouldn't see the device in Campus?
TopoSMFGenerateCdpTopology: No entry found for the device with Id xxxxx( and IP address 10.x.x.x- entry dropped.
Joe Clarke
The device could be filtered out in your Data Collection filters. Without seeing the whole ani.log with debugging enabled, I cannot say for certain.
Typically, devices found in DCR are not in Campus are due to filters or bugs. Make sure you're running the latest version of Campus for your release of LMS.
