Devices Not attempted in Inventory collection
skrowocsic
Hello:
When I do an Inventory Collection, the job doesn´t work with some devices and I have to restart the server.
The job doesn´t fail but the log ICServer.log doesn´t got any information and it works for hours and hours and when it finally stops I can see that devices are not attempted.
I have done some succesfull Inventory Collections with Cisco 3750 switches and 805 routes.
I have tried witch Cisco 2811 routers and 2950 and 2960 switches but it doesn´t work.
I have tried to update my LMS4.0.1 but it doesn´t find any actualization. However, in the Cisco download page there are some patches.
Thanks, Jonan.
It looks like you have to open a TAC case as they are in best position to tell you which patch to install(if needed) to fix this or if any kind of upgrade is required.
you can always upgrade to latest version as it has fix for the older bugs. But you can try the following things and check if this resolves the issue.
1. from the output of "pdshow -brief" Check if ICserver is running.
2. from the location admin>system>softwae centre>device update. you can install avaialble packages.
11 Replies 11
srkala
check if the device credential verification job is successful for these devices. Also if possible try to delete and re-add the device with proper credentials.
Yes, the device credential is sucessfull. I have configured snmp RO, telnet and SSH access.
I´ll try to re-add the devices.
Thanks.
I have re-added a device, checked its credentials, but the Inventory collection doesn´t work.
Can you post the message when inventory fails
The Collection job give this information:
Job Results
No. of Devices Scanned: 22
Duration: 5 hours, 44 minutes, 49.263 seconds
Average Scan Time: 15 minutes, 40.421 seconds/device
Job Result Description: Timed out. Make sure that ICServer is running.
It has processed 22 devices succesfully, the rest are not attempted.
ICserver.log contains:
Exception in thread "Thread-20" java.lang.NoSuchFieldError: hwVersion
    at com.cisco.nm.xms.xdi.pkgs.LibInventory.EntityMibHelperMethods.mapSNMPValsToPort(EntityMibHelperMethods.java:2278)
    at com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatSwitch.ContainmentAGI_ENTITY_Mib.mapSNMPValToCompAttributesProcValsEntExtActiveProcessor(ContainmentAGI_ENTITY_Mib.java:529)
    at com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatSwitch.ContainmentAGI_ENTITY_Mib.populatingTheChassis(ContainmentAGI_ENTITY_Mib.java:284)
    at com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatSwitch.ContainmentAGI_ENTITY_Mib.g$eval(ContainmentAGI_ENTITY_Mib.java:136)
    at com.cisco.nm.xms.xdi.ags.ContainmentAGI.g$eval(ContainmentAGI.java:21)
    at com.cisco.nm.xms.xdi.SdiEngine.initAndEvalAGIs(SdiEngine.java:383)
    at com.cisco.nm.xms.xdi.SdiEngine.request(SdiEngine.java:309)
    at com.cisco.nm.xms.xdi.SdiEngine.getDevRepr(SdiEngine.java:302)
    at com.cisco.nm.rmeng.inventory.ics.core.CollectionController.run(CollectionController.java:687)
    at java.lang.Thread.run(Thread.java:662)
Exception in thread "InvMiscThread1" java.lang.StackOverflowError
    at java.lang.AbstractStringBuilder.append(AbstractStringBuilder.java:390)
    at java.lang.StringBuffer.append(StringBuffer.java:224)
    at com.cisco.nm.rmeng.inventory.ics.misc.InvMiscHandler.getQueueItem(InvMiscHandler.java:126)
    at com.cisco.nm.rmeng.inventory.ics.misc.InvMiscHandler.getQueueItem(InvMiscHandler.java:137)
Populating RME Device Map Cache...
Populating CMF Mdf Cache...
inside checkForUpdate
inside checkForUpdate1
inside checkForUpdate2
checkForUpdate : true
Calling port record
I have got connection
Query : select top 50000 start at 1 a.DCR_ID,b.NetworkElementID,b.EndpointName,b.Description,b.ManagementState,b.EnabledState,b.Speed,b.isFlexLink,b.isSPANEnabled,b.ProtocolIfType,b.TimeOfLastState,b.SNMPIFIndex from DM_Dev_State a,IFEntryEndpoint b where a.NetworkElementID = b.NetworkElementID order by b.NetworkElementID,b.EndpointName
count1 : 17846
Port Record : 17846
Length of Port Record : 17846
Inserting page : 2
java.sql.SQLException: JZ0SB: ?ndice de par?metro fuera de rango: 13.
    at com.sybase.jdbc2.jdbc.ErrorMessage.raiseError(ErrorMessage.java:533)
    at com.sybase.jdbc2.jdbc.ParamManager.checkIndex(ParamManager.java:324)
    at com.sybase.jdbc2.jdbc.ParamManager.setParam(ParamManager.java:374)
    at com.sybase.jdbc2.jdbc.SybPreparedStatement.setParam(SybPreparedStatement.java:1181)
    at com.sybase.jdbc2.jdbc.SybPreparedStatement.setParam(SybPreparedStatement.java:1174)
    at com.sybase.jdbc2.jdbc.SybPreparedStatement.setInt(SybPreparedStatement.java:202)
    at com.cisco.nm.rmeng.inventory.ics.server.DBRecordUpgrade.insertPortAttrRecord(DBRecordUpgrade.java:534)
    at com.cisco.nm.rmeng.inventory.ics.server.DBRecordUpgrade.populatePortRecord(DBRecordUpgrade.java:420)
    at com.cisco.nm.rmeng.inventory.ics.server.DBRecordUpgrade.populatePMCTables(DBRecordUpgrade.java:129)
    at com.cisco.nm.rmeng.inventory.ics.server.ICServer.initialize(ICServer.java:151)
    at com.cisco.nm.rmeng.inventory.ics.server.ICServer.(ICServer.java:76)
    at com.cisco.nm.rmeng.inventory.ics.server.ICServer.main(ICServer.java:325)
My Java version is Java 6 standard edition update 22, build  1.6.0_22-b04.
Hello:
ICserver is running and I update the devices regularly.
I´ll open a case.
Thank you very much.
Hello:
I opened a case and they relationed my problem with a known bug, CSCtq74925. They have provided me 2 patches and my inventory collection works perfectly.
Thank you for your help.
I faced the same problem but in Bug toolkit information is not available regarding patches/workaround (LMS 4.0.1) .
ICServer.log:
Returning false since port table has entries
checkForUpdate : false
    at com.cisco.nm.xms.xdi.pkgs.LibInventory.EntityMibHelperMethods.mapSNMPValsToPortPOE(EntityMibHelperMethods.java:3699)
Can You help?
If it is a Windows server:
lms4.0.1-win-consolidated-rme-sept2011.tar link
If it is a Solaris server:
lms4.0.1-sol-consolidated-rme-sept2011.tar link
There is a readme file with the patch which will help you install it.
Great! Thank you very much. Patch was applied and now IC is working.
