11-09-2009 03:09 AM
We have two cisco 7201 with the following characteristics:
Cisco 7201 (c7201) processor (revision B) with 917504K/65536K bytes of memory.
Processor board ID 78002382
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
1 slot midplane, Version 2.0
The problem is that these devices seem to be supported in RME 4.1.1, but I am not able to view their logs, get their configuration or anything else related to RME. The configuration is no different from any other router that is fully supported by CW.
What might be the problem?
Thank you in advance,
Katerina
11-09-2009 03:58 AM
Is in RME device list in the "normal" state?
Does it show up in the CDA report?
Cheers,
Michel
11-12-2009 05:15 AM
Sorry for the question, but how do I generate the CDA report?
Thnx
11-13-2009 02:53 AM
Hi, everything seems to be ok now. I deleted and re-added the devices.
Thnx for your assistance
