04-22-2020 12:29 AM
devnetsandbox-emea-gwy.cisco.com:20217 i am unable to connect to the vpn
04-22-2020 01:10 AM
I can reach
and get login pop up. Doesn't look like its a headend issue.
You might want to check local settings and try to connect to known working VPN connection to test. Any upstream firewall blocking ports?
hope this helps
please don't forget to rate helpful posts
04-22-2020 02:21 AM
04-22-2020 02:53 AM
try telnet -
omz@mac ~ % telnet devnetsandbox-emea-gwy.cisco.com 20217 Trying 173.38.221.89... Connected to devnetsandbox-emea-gwy.cisco.com. Escape character is '^]'. ^] telnet> quit Connection closed. omz@mac ~ %
You should see connected .. if you don't .. I suspect the port 20217 is being blocked
