ROUTING-FIB-3-UPD_MSG_TOO_BIG
aridy
I am using a Cisco ASR 9010 with a Version 6.4.2 IOS XR.
I got the following error 4 times:
ipv4_rib[1160]: %ROUTING-FIB-3-UPD_MSG_TOO_BIG : attribute ID: 0x3130, size: 7748, data: 5FFFFFFFF3286C000000020000000000000171FFFFFF975729FFFFFFF90000001469705F6267705F617474725F7269625F62616700000306FFFFFF870000000200FFFFFFAE526C00FFFFFFAE55FFFFFFF100000000000007FFFFFF8000000002000000FFFFFFE0000000000000000000000000000000FFFFFFAE0000000000000000 not distributed to FIB, too big to fit IPC buffer, 7754 > 5821
Two times it had no other errors appearing, but two other times it was together with the following log:
ipv4_rib[1160]: %ROUTING-FIB-3-ASSERT_RL : FIB internal inconsistency detected: upd msg encode 5397 Requested 8908 bytes of data, space for 8128 : ipv4_rib : (PID=7324) : -Traceback= 7f8ecd050141 7f8ecd261f27 7f8ecd2620c5 7f8edae033e5 55704d95183c 55704d95c7d8 55704d98040f 55704d96444c 7f8edd057c18 7f8edd06bfcb 7f8edd05bc9d 7f8edd02a291 7f8edd02a4db
There is no information on Cisco Docs for this issue so i want to ask if any one encountered this message.
Thanks in advance,
Aridy
Mark Elsen
 - Possibly a  software bug, if applicable and or feasible try a more recent software release for your device. Check if the problem persists afterwards.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for the answer.
Do you think it affects my router somehow or it is just a log message?
Aridy
 - It could in worst case affect connectivity for particular route or routes, and the initial advisory is still applicable.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
