devnetsandbox-emea-gwy.cisco.com:20217
devnetsandbox-emea-gwy.cisco.com:20217 i am unable to connect to the vpn
omz
I can reach
and get login pop up. Doesn't look like its a headend issue.
You might want to check local settings and try to connect to known working VPN connection to test. Any upstream firewall blocking ports?
hope this helps
please don't forget to rate helpful posts
i am getting this error
try telnet -
omz@mac ~ % telnet devnetsandbox-emea-gwy.cisco.com 20217
Trying 173.38.221.89...
Connected to devnetsandbox-emea-gwy.cisco.com.
Escape character is '^]'.
telnet> quit
Connection closed.
omz@mac ~ %
You should see connected .. if you don't .. I suspect the port 20217 is being blocked
