DFM 3.0.1 device discovery problem
mdruppe98
Hi, I have 329 devices in DFM that are "pending", I'm having trouble porgressing any more than that. Please advise.
Mark
7 Replies 7
Joel Monge
First thing you should do is upgrade to DFM 3.0.5. There are known memory leak problems in earlier versions.
It looks like 3.0.1 is the highest version I can get. I'm running LMS 3.0 and I upgraded to DFM 3.0.1 a few days ago. When I select download updates for DFM it says "no updates available for selected products".
Oh, LMS 3.0. You need to first move to 3.0.1 bundle update and then you can update DFM. You can download bundle update here:
http://www.cisco.com/cgi-bin/tablebuild.pl/lms301
Ok, great. thanks. Let me try that and then try updating to DFM 3.0.5.
Mark
mdruppe98
I upgraded everything and now I'm at DFM 3.0.5. I imported all the devices but I'm still showing them as learning int the device summary.
How long have you waited for the discovery? Go to DFM > Device Management > Rediscover/Delete and check at what percentage the devices are stuck in learning. Are all the devices stuck or are some getting discovered?
mdruppe98
I spoke too soon!!!! They are "known" now. Thanks a million for your help!
Mark
