04-30-2010 06:51 AM
Hi, I have 329 devices in DFM that are "pending", I'm having trouble porgressing any more than that. Please advise.
Mark
04-30-2010 07:03 AM
First thing you should do is upgrade to DFM 3.0.5. There are known memory leak problems in earlier versions.
04-30-2010 07:11 AM
It looks like 3.0.1 is the highest version I can get. I'm running LMS 3.0 and I upgraded to DFM 3.0.1 a few days ago. When I select download updates for DFM it says "no updates available for selected products".
04-30-2010 07:14 AM
Oh, LMS 3.0. You need to first move to 3.0.1 bundle update and then you can update DFM. You can download bundle update here:
04-30-2010 07:30 AM
Ok, great. thanks. Let me try that and then try updating to DFM 3.0.5.
Mark
04-30-2010 11:53 AM
I upgraded everything and now I'm at DFM 3.0.5. I imported all the devices but I'm still showing them as learning int the device summary.
04-30-2010 12:01 PM
How long have you waited for the discovery? Go to DFM > Device Management > Rediscover/Delete and check at what percentage the devices are stuck in learning. Are all the devices stuck or are some getting discovered?
04-30-2010 12:18 PM
I spoke too soon!!!! They are "known" now. Thanks a million for your help!
Mark
