DFM and ACS Integration
malvadobladez
I have LMS 2.5 running integrated with ACS 3.3 and everything seems to be workng correctly, except for DFM 2.0.
The problem I am having is DFM shows no devices that are being monitored or discovered, If I change the security model to local or tacacs+ all my devices show up.
Has anyone else seen this problem? If so how did you get around this issue?
nhabib
Level 9
Level 9
Make sure the devices are entered properly in ACS
(might need to enter them via fully qualified domain name)
