DFM and Redundant Power
9tgonzalez
Can DFM alert if RPS fails?
For example I have a 3750 stack of 6 switches on one RPS2600. If the RPS fails or looses power but the 3750s are OK running on their primary power, can I get an alert?
8 Replies 8
Joe Clarke
I don't have a 3750 with an RPS which which to test, but if you go to DFM > Device Management > Device Details and launch the Detailed Device View for this switch, do you see any Power Supply objects under the Environment folder?
I see the primary power supply status (all 6 from the stack) but there is no redundant status.
Thanks.
Please post an snmpwalk of 1.3.6.1.4.1.9.9.13.1.5.
Here is the snmpwalk, Thanks:
SNMP Walk Output
.1.3.6.1.4.1.9.9.13.1.5
CISCO-ENVMON-MIB::ciscoEnvMonSupplyStatusDescr.1003 = STRING: Sw1, PS1 Normal, RPS Normal
CISCO-ENVMON-MIB::ciscoEnvMonSupplyStatusDescr.2003 = STRING: Sw2, PS1 Normal, RPS Normal
CISCO-ENVMON-MIB::ciscoEnvMonSupplyStatusDescr.3003 = STRING: Sw3, PS1 Normal, RPS Normal
CISCO-ENVMON-MIB::ciscoEnvMonSupplyStatusDescr.4003 = STRING: Sw4, PS1 Normal, RPS Normal
CISCO-ENVMON-MIB::ciscoEnvMonSupplyStatusDescr.5003 = STRING: Sw5, PS1 Normal, RPS Normal
CISCO-ENVMON-MIB::ciscoEnvMonSupplyStatusDescr.6003 = STRING: Sw6, PS1 Normal, RPS Normal
CISCO-ENVMON-MIB::ciscoEnvMonSupplyState.1003 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonSupplyState.2003 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonSupplyState.3003 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonSupplyState.4003 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonSupplyState.5003 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonSupplyState.6003 = INTEGER: normal(1)
CISCO-ENVMON-MIB::ciscoEnvMonSupplySource.1003 = INTEGER: ac(2)
CISCO-ENVMON-MIB::ciscoEnvMonSupplySource.2003 = INTEGER: ac(2)
CISCO-ENVMON-MIB::ciscoEnvMonSupplySource.3003 = INTEGER: ac(2)
CISCO-ENVMON-MIB::ciscoEnvMonSupplySource.4003 = INTEGER: ac(2)
CISCO-ENVMON-MIB::ciscoEnvMonSupplySource.5003 = INTEGER: ac(2)
CISCO-ENVMON-MIB::ciscoEnvMonSupplySource.6003 = INTEGER: ac(2)
The state should change to critical when the main PS switches to the RPS. This will trigger an event in DFM.
I was hoping to get an alert if the RPS lost power. Last week I discovered a power cord for RPS supplying backup power for 6 3750 switches was unplugged. It would be nice if there was a way to be alerted if the RPS is not available even if the 3750s have primary power.
Based on your SNMP output, it does not appear the 3750s have the instrumentation to provide such data.
Thanks for your help.
