06-16-2011 11:41 PM
We got suddenly a lot of Voltage faults in DFM from 10GE ports at our VSS Core. Communication is not affected.
All other devices show voltage in a valid range and the VSS before this night as well.
An "shut / no shut" of the interface doesnt help, CLI confirms the problem, see below.
What does it mean? What can we do that this faults disappears?
fli_rie_core254#sh interfaces transceiver switch 1
Transceiver monitoring is disabled for all interfaces.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
Optical Optical
Temperature Voltage Current Tx Power Rx Power
Port (Celsius) (Volts) (mA) (dBm) (dBm)
Te1/1/1 33.8 0.00 45.7 -- -1.4 -32.2 --
Te1/1/2 32.3 0.00 42.3 -- -1.5 -1.2
Te1/1/3 31.5 0.00 42.0 -- -1.5 -2.8
Te1/1/4 28.7 0.00 43.3 -- -1.4 -2.7
Te1/1/5 29.7 0.00 43.0 -- -1.5 -2.7
Te1/1/6 28.4 0.00 45.8 -- -1.4 -4.9
Te1/1/8 26.2 0.00 43.2 -- -1.4 -37.0 --
Te1/2/1 30.2 0.00 41.3 -- -2.1 -33.0 --
thx for help in advance,
Steffen
06-17-2011 12:05 AM
Hi, do you know the command to get the current/power consumption info, or anything like this? Thanks.
06-17-2011 10:20 AM
No,
Have your question something to do with the initiated discussion?
Gesendet: Freitag, 17. Juni 2011 09:06
An: Neuser, Steffen
Betreff: New message: "DFM@LMS4.0.1: lots of Voltage meassage from 10GE ports"
Cisco Support Community<>>
Re: DFM@LMS4.0.1: lots of Voltage meassage from 10GE ports
created by Shuo Fang<> in Network Management - View the full discussion<>>>
