DFM@LMS4.0.1: lots of Voltage meassage from 10GE ports
STEFFEN NEUSER
Level 4
Level 4
We got suddenly a lot of Voltage faults in DFM from 10GE ports at our VSS Core. Communication is not affected.
All other devices show voltage in a valid range and the VSS before this night as well.
An "shut / no shut" of the interface doesnt help, CLI confirms the problem, see below.
What does it mean? What can we do that this faults disappears?
fli_rie_core254#sh interfaces transceiver switch 1
Transceiver monitoring is disabled for all interfaces.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                         Optical   Optical
            Temperature  Voltage  Current   Tx Power  Rx Power
Port        (Celsius)    (Volts)  (mA)      (dBm)     (dBm)
Te1/1/1       33.8       0.00      45.7 --   -1.4     -32.2 --
Te1/1/2       32.3       0.00      42.3 --   -1.5      -1.2
Te1/1/3       31.5       0.00      42.0 --   -1.5      -2.8
Te1/1/4       28.7       0.00      43.3 --   -1.4      -2.7
Te1/1/5       29.7       0.00      43.0 --   -1.5      -2.7
Te1/1/6       28.4       0.00      45.8 --   -1.4      -4.9
Te1/1/8       26.2       0.00      43.2 --   -1.4     -37.0 --
Te1/2/1       30.2       0.00      41.3 --   -2.1     -33.0 --
thx for help in advance,
Steffen
cassiefang
Hi, do you know the command to get the current/power consumption info, or anything like this? Thanks.
No,
Have your question something to do with the initiated discussion?
Von: cassiefang
Gesendet: Freitag, 17. Juni 2011 09:06
An: Neuser, Steffen
Betreff: New message: "DFM@LMS4.0.1: lots of Voltage meassage from 10GE ports"
Cisco Support Community<>
Re: DFM@LMS4.0.1: lots of Voltage meassage from 10GE ports
created by Shuo Fang<> in Network Management - View the full discussion<>
