DFM@LMS4.0.1 - no devices for Polling and Thresholds
STEFFEN NEUSER
Level 4
Level 4
DFM with LMS4.0.1 got all wanted devices and is working fine so far except of we cant do settings on Polling & Thresholds, because we cant select anything:
How can we solve the problem? Many thx for hints in advance,
Steffen
Joe Clarke
This is expected.  You can only adjust polling and threshold parameters on groups.  You cannot select individual devices.  If you want to be able to control polling parameters or thresholds at the device level, you will need to customize one of the customizable fault groups to match the devices in question.  Then you can adjust the polling and threshold group priorities so that customizable group is closer to the top.  Apply your changes, then go and adjust the desired settings.
