DHCP Config on Cisco layer-3 6509 switch
pankaj_mrec
Can i config the DHCP on the layer-3 6509 switch without using any DHCP server?
umedryk
Level 5
Level 5
Not sure whether you are asking about making a cat6k switch as DHCP server or client? If you are thinking of making it as a client, then what is the use if you don't plan to have a server ?
Actually I want to make a cat6k switch as a server.
Sample config on a 6500 with MSFC
ip dhcp pool 0
network 10.40.4.0 255.255.255.0
default-router 10.40.4.232
lease infinite
You can exclude IP addressess or ranges to refine your scope
ip dhcp excluded-address 10.40.4.1 10.40.4.42
ip dhcp excluded-address 10.40.4.44 10.40.4.254
In this case only 10.40.4.43 would be availabel for issue.
