DHCP not working
Amills
I have an ISR4321 router and a 2960x switch. I setup a super basic config, with DHCP. My laptop never gets an IP address. Static works fine to get to the internet.
ISR4321/K9 running 16.09.04
hostname Test-Router
ip name-server 8.8.8.8 1.1.1.1
ip dhcp excluded-address 10.0.1.65
ip dhcp excluded-address 10.0.1.225
ip dhcp excluded-address 10.0.1.2 10.10.1.11
ip dhcp pool USERS-1
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
domain-name test.com
dns-server 1.1.1.1 8.8.8.8
interface GigabitEthernet0/0/0.1
description Network
encapsulation dot1Q 1 native
ip address 10.0.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/1
description ISP
ip address dhcp
ip nat outside
negotiation auto
ip nat inside source list 42 interface GigabitEthernet0/0/1 overload
ip route 0.0.0.0 0.0.0.0 dhcp
ip ssh authentication-retries 5
ip ssh version 2
access-list 12 permit 10.0.1.0 0.0.0.255
access-list 42 permit 10.0.1.0 0.0.0.255
access-list 55 permit 10.0.1.0 0.0.0.255
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 12 in
exec-timeout 5 0
logging synchronous
login local
transport input telnet ssh
switch config
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960xr-48fps-i
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/0/2
switchport mode access
interface GigabitEthernet1/0/48
interface Vlan1
ip address 10.0.1.225 255.255.255.0
ip default-gateway 10.0.1.1
line con 0
line vty 5 15
end
Glad that you got it to work. I looked at the posted config and see why your PC was not able to get an IP address using DHCP. The config had this
This excludes every address in 10.0.1.x other than the router address. So this issue is pretty much self inflicted.
Rick
Amills
So, I blasted the router config away, reloaded, entered in each command manually instead loading it from a backup config file or copy and paste from a notepad.  Now it works. Man, these ISR4321 routers frustrating. Lots of little issues with these guys.
Rick
Amills
That would explain when I entered the config manually line by line it worked. Too much tunnel vision to see the issue, the joys of working alone, thank you for that eagle eyed catch.
You are quite welcome. I have spent enough time working alone to appreciate what you say. It is one of the reasons why I find this community so valuable. Hope you will continue to be active in the community.
Rick
