Dhcp pool
avionics
Are there any processes to analize the dhcp pool interface on a cisco router?
jsivulka
Level 10
Level 10
I think show ip dhcp pool command will help it will Displays information about the DHCP address pools. DHCP Option 43 is limited to one access point type per DHCP pool. You must configure a separate DHCP pool for each access point type.
