Difference between Routers
IrfanKhan4904
What is the difference between two Routers?
ROUTER :1
Cisco IOS Software, 7200 Software (C7200-JS-M), Version 12.4(13b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 25-Apr-07 03:18 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T1, RELEASE SOFTWARE (fc1)
NAMAL-7206 uptime is 3 days, 6 hours, 56 minutes
System returned to ROM by reload at 06:05:35 GMT Tue Nov 10 2020
System image file is "disk2:c7200-js-mz.124-13b.bin"
Last reload reason: Reload Command
Cisco 7206VXR (NPE-G1) processor (revision B) with 983040K/65536K bytes of memory.
Processor board ID 32610525
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.8
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
3 Gigabit Ethernet interfaces
509K bytes of NVRAM.
62592K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
ROUTER:2
Router#show version Cisco IOS Software, 7200 Software (C7200-IPBASEK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2010 by Cisco Systems, Inc. Compiled Tue 23-Mar-10 12:27 by prod_rel_team ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1) BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(15), RELEASE SOFTWARE (fc3) Router uptime is 2 hours, 2 minutes System returned to ROM by reload at 12:07:26 GMT Fri Nov 13 2020 System image file is "disk2:c7200-ipbasek9-mz.124-24.T3.bin" Last reload reason: Reload Command This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. Cisco 7206VXR (NPE-G1) processor (revision B) with 491520K/32768K bytes of memory. Processor board ID 32871194 SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache 6 slot VXR midplane, Version 2.9 Last reset from power-on PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points. Current configuration on bus mb1 has a total of 0 bandwidth points. This configuration is within the PCI bus capacity and is supported. PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points. Current configuration on bus mb2 has a total of 0 bandwidth points. This configuration is within the PCI bus capacity and is supported. Please refer to the following document "Cisco 7200 Series Port Adaptor Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com> for c7200 bandwidth points oversubscription and usage guidelines. 3 Gigabit Ethernet interfaces 509K bytes of NVRAM. 250368K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes). 16384K bytes of Flash internal SIMM (Sector size 256K). Configuration register is 0x2102 Router#
Richard Burts
Differences are:
- different versions of code. 12.4(13b) and 12.4(24)T3
- different code train. R1 is main line while R2 is T train. new features get introduced in T train and only moved to main line at version updates.
- different bootstrap. 12.3(4r)T1 and 12.3(4r)T3
- different amount of memory.  983040K/65536K and 491520K/32768K
- R2 is C7200-IPBASEK9-M it is not clear whether R1 is also IPBASE or not
Is there a reason for asking?
Rick
I want to upload the configuration of one router to another router. But facing issues.
So how I can upgrade the Router?
I want this version on another cisco router 7206VXR.
If you want 12.4(13b) on another 7206 the easy way to do it would be to copy it from your 7206 that is running it to a server (might be tftp server or ftp server or scp server) and then copy from the server to the other 7206.
I am not sure what the issue is about load the config from one 7206 to another 7206 and what that has to do with the version of code. Can you explain further?
Rick
