different between central office and point of presence
daniel4579329
hi everyone
im learning to ccna 200-301 and i wonder if someone can explain to me the
thanks (:
omz
HQ is usually referred to as Central Office.
Depending on the company size and requirements, they either build their own Data Centers or use a POP location to host their equipment.
"A point of presence (PoP) is an artificial demarcation point or interface point between communicating entities. A common example is an Internet point of presence, the local access point that allows users to connect to the Internet with their Internet service provider (ISP).[1] A PoP typically houses serversroutersnetwork switches, multiplexers, and other network interface equipment, and is typically located in a data center. ISPs typically have multiple PoPs. PoPs are often located at Internet exchange points and colocation centres." Wikipedia
sorrt i didnt fully understand, can you explain a bit more
(i think it would be better if you give me a definition for each one)
