Disable Radio on RV340W Router
SB-TRE123
Hello people!
I own an Cisco RV340W router.
Sadly there is no option to turn off radio (2,4 and 5 Ghz wireless network) by schedule. By turning off I mean "turn off", not only preventing connection.
I tried to connect by telnet or ssh but down't seem to be supported on this device. Using the SNMP protocol („snmpwalk“) I could not find any OID for wireless settings or enabling/disabling an interface.
So my question:
Any idea how I could switch the radio on/off directly on the device or remotely?
Thank you!
Samuel
SB-TRE123
Or does anyone know a way to ask Cisco staff about the issue – Without having a support contract?
The configuration guide also mentions the REST API for "future use".
THANKS FOR YOUR HELP
