Disable Reverse Telnet on Cisco Nexus 5548
twtoth1988
We are currently using Solarwinds to run Compliance Reports for all our Cisco hardware.
One of the criteria is Disabling reverse telnet on these devices.
Previously I have done this under '
Line-console-0
transport input/transport preferred none
This has worked on other routers and switches, but on a few of our Nexus 5548's I can't get this command to run at all.
Under the line console section, there doesn't appear to be a way (or at least an obvious way) to disable this feature.
I'm sure it's just a syntax change in the CLI, but I'm trying to clear up these reports, does anyone know the commands for this?
Mark Malone
2 other ways i can think of that might work
1 access list on the VTY block port 23 completely , inbound and out
2 turn off the feature from global config , no feature telnet
