Disable SNMP on an interface
Chuan Liu
I want to disable SNMP on a specific interface so that management programs are not able to know anything about this interface. Is there a way to do this?
Thanks.
yjdabear
Provided "snmp-server ifindex persist" is used in tandem, a simplistic approach is to configure "snmp-server view" to exclude a particular interface from being learned by incoming initial SNMP query against the ifEntry.
snmp-server view secretView ifEntry.*.# excluded
where # is the ifIndex number of that interface. This could make simple-minded NM software assume there's no interface at that ifIndex #. Of course, a more sophisticated program could always poll a specific OID for non-ifEntry info still, in which case you need to have more SNMP views configured to block other specific MIBs.
Here's a doc on SNMP view:
http://www.cisco.com/warp/public/477/SNMP/snmpsecurity-20370.html
As far as outgoing SNMP traps, you can configure "no snmp trap link-status" etc. on the interface.
yjdabear
