Discover in Prime Infrastructure 1.3
paul.parquet
I've a little problem, I've lot of switch in Device Work Center in Managed with Warnings, the cause is the enable password is wrong.
So I deleted all the switch whith warnings and rediscover with the correct password and enable password. But the switch appeared again in Managed with Warnings state !
When I edit a switch in this state, the box enable is always empty ? What's wrong ?
Paul
Rollin Kibbe
Hi Paul:
It may be because your discovery settings aren't specified to include the enable password in the job.  Under Operate > Discovery, there's a Discovery Settings link in the top right corner of the page.  Make sure that your job has the enable password checked to be included, and that it's correct.
Does this work if you go to the Device Work Center itself and just add the device, rather than discover it?
