DMVPN logging; logging source-interface vlan x - does not work
Hi Guys,
I have spent some time investigating above issue but without any success.
Problem is simple.
 syslog logging service instead of using VLAN interface is using one of the active tunnel interfaces:
 config:
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Loopback0                  10.254.254.230  YES NVRAM  up                    up
NVI0                       10.254.254.230  YES unset  up                    up
Tunnel0                    10.254.1.230    YES NVRAM  up                    up
Tunnel1                    10.254.2.230    YES NVRAM  up                    up
Vlan1                      10.132.0.250    YES NVRAM  up                    up
logging source-interface Vlan1
logging host 10.191.13.151
Any knowledge about that bug or maybe this is expected behaviour?
Cheers!
Jeff M
Community Member
I have this issue, but not specifically with DMVPN. My issue is on an ASR1002
I have a logging server on 10.10.10.20
Lo0 is 172.31.31.1 /32
Ge0/0 is 192.168.101.0 /24
my config contains :
logging source-interface Loopback0
logging trap notifications
logging host 10.10.10.20
Syslog arrives on 10.10.10.20 but sourced from GE0/0.... Frustrating...
I have exactly the same problem on a ISR 4451.
Same config, same result..
