Does Cisco Prime Infrastructure supports monitoring CPU,Memory, HDD for UCS , VMWare?
ramnaray
nkavuri
Prime Infrastructure/ Assurance is  positioned today more towards managing network elements and network performance,  rather than server infrastructure. We are in the process of adding Datacenter  component support, with more focus on Nexus and UCS- due later this  year.
Having said that, Prime Infrastructure allows the system user to  add custom SNMP polling templates, which can then be used for polling any SNMP  based values from any SNMP enabled device. These can be used to collect the  information you specified below and the polled information will be available in  dashboards and reports.
