Domain-Name Lookup not working on Nexus-5K
Cheto
Stuck on this one, I'm simply trying to configure NTP with hostnames but its unable to resolve any hostnames. I have the following commands.
ip domain-lookup
ip name-server 8.8.8.8 use-vrf management
I can ping 8.8.8.8 from my management vrf but DNS will not resolve anything, but when I try to ping google.com it just says
% Invalid host/interface google.com
marce1000
 - As far as ping is concerned try iping  (and or iping -h to get command optons for specifying a VRF). Usually an NTP server is defined by IP address because it is only resolved 'once' when defined (only the resolved-ip is used in the configuration). For the NTP server you should be able to specify a VRF on the command line-options. Use the ? mark at will to get command options in a particular stage when entering the ntp server command.
 M.
Thanks, I figured out that the ip name-server commands has to be under the vrf context management to resolve DNS. Thats why DNS wouldn't resolve.
Thanks for the information on that, I didn't realize it would just input the IP address instead of the hostname.
Glad you were able to find the answer to your own issue. +5 for sharing what you learned.
Rick
Rick
