draw wan link in topology
ohassairi
Level 5
Level 5
hello
we have 2 routers connected via mpls link provided by our isp
when we make sho cdp neighbor, each router cannot see the other. i understand this is normal.
is it possible to let each router sees the other one as a neighbor?
i think if we can do this, so in cw lms / topology services, we will obtain one link  between both routers. and the map will be more meaningful. isn't it?
5 Replies 5
Joe Clarke
Campus, at this time, still requires CDP/ILMI/ELMI to draw interconnections.  In an MPLS environment, CDP just isn't there, so you will not see the links.
hi joe
i configured one ip/gre tunnel between both routers, then i added the command cdp enable under interface tunnel0
the results:
- i got cdp running between both routers
- the wan link was drawn in network topology  ;-)
Good.  Many customers using MPLS cannot enable CDP, and thus Campus typically does not work in an MPLS environment.  However, it should be pointed out that there is nothing magic in what Campus Manager does.  As long as CDP, ILMI, or ELMI can be negotiated between two peers, and those peers are both managed by Campus, then a link can be drawn between the two of them.
Hi Joe
the tunnel link speed is shown 100K in network topology!
i tried to change it using bandwidth command under interface tunnel0 but nothing has changed.
how CM determines the link speed? and could it be changed?
CM uses ifSpeed to get this.  Yes, it should be dictated by the bandwidth command, but you would need to do another Campus Data Collection after changing the bandwidth.
