dual-active detection and fast hellos
Eric R. Jones
Level 4
Level 4
Good morning, I'm trying to deploy 2 WS 6509 E chassis with 152 1 SY1a advanced enterprise mk 9 IOS using dual-active detection with fast hellos.
When I enter the configuration commands:
interface port-channel 10
description vsl link from switch 1
switch virtual link 1
shutdown
exit
exit
switch virtual domain 20
shutdown
exit
exit
!switch convert mode virtual
switch 1
I get to this point and there's no such command "dual-active" available.
So at this point I get "^" symbol and the configuration fails from here on.
dual-active detection pagp
dual-active detection pagp trust channel-group 10
!dual-active fast-hello
!dual-active exclude interface "management ports"
exit
no shutdown
exit
Has anyone dealt with this configuration on the newer Sup 2T blades with 152 - 1 SYA1 IOS file?
ej
Rolf Fischer
Level 9
Level 9
Is this a typo? The correct syntax is 'dual-active detection fast-hello', but normally it is not necessary to enable fast-hello because it is enabled by default.
You can check the status with the command 'show switch virtual dual-active fast-hello'; this command has the optional keywords 'counters' and 'packets'
Rolf
Thanks for the reply.
Yes that was a typo and I have read that this function is on by default; however, I was directed to turn on dual-active detection. With this in mind is the below correct?
switch 1
exit
or is this one correct eliminating the dual-active detection fast-hello?
switch 1
exit
I understand what it's supposed to do and thought I understood how to configure it; however, when not seeing "dual-active" command I began to wonder if this configuration is IOS specific.
Sine we are running s2t54-adventerprisek9-mz.SPA.152-1.SY1a.bin and all the descriptions relate to version 12.2 I began to wonder if there is a different method.
ej
No; if you want to disable DAD fast-hello, you need to configure
(config-vs-domain)#no dual-active detection fast-hello
However, apart from testings I see no reason to disable it.
