03-18-2019 03:44 AM - edited 03-19-2019 12:20 AM
Hi all
Can I use Cisco router 1841 as E1 over IP.
If not, which is Cisco series used?
03-18-2019 01:53 PM
I believe that what you are looking for is the feature Circuit Emulation over IP. I do not find documentation that it is supported on 1841. I did find documentation (using Cisco Feature Navigator) that it is supported in 3945 running version 15.2(1)T. Note that this feature requires a specific Network Module and that limits the platforms on which it is available.
Rick
03-18-2019 11:54 PM
03-19-2019 06:30 AM
E1 over IP is pretty unusual and seems not supported on 1841. IP over E1 is quite common and is certainly supported on 1841.
Rick
