Easy Qos on APIC-EM
DAVID
Level 3
Level 3
Any one using EasyQos on APIC to configure and monitor their QOS deployments? We have both APIC-EM and LiveAction but right now use neither for any QOS configuration.  I'd like to get unbiased opinions of both.
yeter1234
I have APIC-EM and easy Qos running in a pre-prod environment. It works fine for all catalyst series except for the catalyst 9300 which is supposedly Cisco's poster child SDN enabled switch of the future. How ironic :)
Just drag and drop applications (which are discovered at edge via NBAR2 AVC) and place them into either 1)Business relevant 2) irrelevant or 3) default list  and APIC-EM does all the heavy lifting via pushing platform based MQC via SSH/SNMP or CLI depending on the switch model.
Steve K
It does work on the 9300, but not with a network essentials license. DNA Essentials license is a requirement.
