EEM - Add cli data to different variables
fsebera
Level 9
Level 9
Hello, I'm hoping to get some help with my EEM script - I tried everything except what works.
My EEM script:
action A cli command "enable"
action B cli command "show crypto session | i port"
action C foreach BBBB "$_cli_result" "\n\n\s"
action D end
action E puts nonewline "BBBB=\n\n$BBBB"
action Z exit
Results:
BBBB=
Peer: 10.0.3.1 port 500
Peer: 10.0.2.1 port 500
Peer: 20.0.3.1 port 500
Peer: 20.0.2.1 port 500
What I am trying to accomplish is to get each of the 4 line IP addresses assigned to different variables. ANY help would be appreciated.
Thank you
Frank
fsebera
Level 9
Level 9
UPDATE!!!!
I found if I use a different EEM feature I get closer to my goal but sadly still not 100%
Please note, I am attempting to make this script dynamic as possible by not nailing down the IP addresses as I support a test lab and I will not know the IP address in use up front.
Still hoping for help!!!
My NEW EEM script:
action C regexp "([1]+)([0-9.]+)([0-9.]+)([0-9]+)" "$_cli_result" IPADDR1
action D regexp "([2]+)([0-9.]+)([0-9.]+)([0-9]+)" "$_cli_result" IPADDR2
action E puts "IPADDR1 = $IPADDR1"
action F puts "IPADDR2 = $IPADDR2"
action Z exit
NEW Results:
IPADDR1 = 10.0.3.1
IPADDR2 = 20.0.3.1
ORIGINAL RESULTS:
So I now have about 50% but hoping for 100%!! I'll keep hacking away.
Frank
Dan Frey
It would be easiest take actions as your iterating over the IP addresses in the foreach loop of the EEM applet.  Variable values are not persistent between scripts runs unless contexts are used.   EEM applets can not have a variable name that is itself a variable and you will need EEM TCL to do this.   Here is an example of an EEM TCL file that uses an array data structure to store and call the key value pairs and an example of storing the ip addresses to different variable names.
::cisco::eem::event_register_none
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
# Open the CLI
if [catch {cli_open} result] {
   error $result $errorInfo
} else {
    array set cli1 $result
# Go into enable mode
if [catch {cli_exec $cli1(fd) "en"} result] {
if [catch {cli_exec $cli1(fd) "show ip int brief | inc 10" } result ] {
# stuff into array
set lines [split $result "\n"]
array set intfIps [list]
set counter 1
foreach line $lines {
    if  [regexp {(\d+.\d+.\d+.\d+).*} $line -> intfIp] {
        append intfIps(var$counter) $intfIp
        #create variables (var1, var2, etc..)
        set var$counter $intfIp
        incr counter
# Get Array key value pairs
foreach {key value} [array get intfIps] {
    puts "key: $key value: $value"
catch {cli_close $cli1(fd) $cli1(tty_id)}
###########end
C1111#event manager run ipaddress2variable.tcl
key: var3 value: 10.249.249.1
key: var4 value: 10.128.128.1
key: var5 value: 10.129.129.1
key: var1 value: 10.253.254.1
key: var6 value: 10.130.130.253
key: var2 value: 10.129.130.1
Hi Daniel,
We are out of office every other week (Covid-19), thus delayed reply.
Thank you for your reply. I am considering looking into the "context" option first. If you have any helpful hints, I'd welcome them!!!!
Thank you
Frank
