EEM and TcL Script to Disable Inactive Ports
cle.co2004
Beginner
Beginner
I've browsed around to the other  support strings to make sure I didn't miss anything, but I can't seem to  get this to work.  I have the latest sl_suspend_ports.tcl and  tm_suspend_ports.tcl created by Joseph Clarke from strings that verified they worked as planned.   Here are the commands I issued to register the scripts -
Directory of flash:/policies/
    9  -rwx        3101   May 3 2013 07:58:03 +00:00  sl_suspend_ports.tcl
   10  -rwx        4669   May 3 2013 07:58:44 +00:00  tm_suspend_ports.tcl
conf t
event manager directory user policy flash:/policies
event manager policy sl_suspend_ports.tcl
event manager environment suspend_ports_days 1
event manager environment suspend_ports_config flash:/susp_ports.dat
event manager policy tm_suspend_ports.tcl
#show run | inc event manager environment
It doesn't appear to work though.  Essentially, we have a  need to make sure all computers are always on and all ports not active  for >24 hours to be shutdown and moved to a designated vlan (I added  the 'lappend' statement to the script to specify the additional command of assigning the vlan)
I'm running 12.2(55)SE7 on Catalyst 3560s and 3750s
Is there a way to manually run the script?  Did I miss anything in the configuration?
Thanks for your help!
Chris
