EEM applet: context retrieve with variables pattern?
Hello!
For example, save variables: var1, var2, var3 by variables pattern: var* to single context key: vars.
event manager applet ctx_save
event none
 action 1.0 set var1 1
 action 2.0 set var2 2
 action 3.0 set var3 3
 action 4.0 context save key vars variable "var*"
But, how retrieve?
event manager applet ctx_retrieve
event none
 ! action 1.0 context retrieve key vars variable "var*"
 ! retrieve data, but how access to values?
How to retrieve variables and access to its values using the same pattern?
balaji.bandi
I do believe that is possible, in a programming point of view, what is the var stored? what value does it retrieve from 1 or 2 or 3?
here is some guidelines :
https://community.cisco.com/t5/networking-documents/eem-built-in-quot-action-quot-variables/ta-p/3123406
you can call variable when the action required.#
BB
Seb Rupik
Hi there,
This is not a function I have used before, but having read up on it the pattern is:
context save key <key_name> variable <variable_name>
context retrieve key <key_name> variable <target_variable_name>
So an example would be:
action 4.0 context save key k_var1 variable "var1"
action 4.1 context save key k_var2 variable "var2"
action 4.2 context save key k_var3 variable "var3"
action 5.0 retrieve key k_var1 variable "old_var1"
action 5.1 retrieve key k_var2 variable "old_var2"
action 5.2 retrieve key k_var3 variable "old_var3"
action 6.0 syslog msg "Old variables, $old_var1, $old_var2, $old_var3"
cheers,
Seb.
